TuanPham1999
7 years agoFrequent Visitor
Pull data from API using POST method in Power BI
Hi all, I'm a fresher in Power BI Desktop. my mission is extract data from given credentials include: ClientID, Password and Url. The credentials must be Base64 encoded for use in the POST /oauth2/to...
- 7 years ago
You may refer to the following post.
https://community.powerbi.com/t5/Desktop/Connect-to-a-Web-Service-sending-parameters/td-p/225510
TuanPham1999
Hi all, I'm a fresher in Power BI Desktop. my mission is extract data from given credentials include: ClientID, Password and Url. The credentials must be Base64 encoded for use in the POST /oauth2/token request. I have used that credentials in Postman and I got its header such as: Authorization: Basic xxxxxxxxxxxxxxxxxxxxxx. what should i start with all of them to get data from API. Can anyone help me to solve this probleml. thank you so much for any solution and suggestion. Cheer!!!
