TuanPham1999
7 years agoFrequent Visitor
Pull data from API using POST method in Power BI
Hi all, I'm a fresher in Power BI Desktop. my mission is extract data from given credentials include: ClientID, Password and Url. The credentials must be Base64 encoded for use in the POST /oauth2/to...
- 7 years ago
You may refer to the following post.
https://community.powerbi.com/t5/Desktop/Connect-to-a-Web-Service-sending-parameters/td-p/225510
Thiaan
5 months agoRegular Visitor
if you add content ie:
Content = Text.ToBinary(postData)
to the web.conents on the call it automatically does a post. just send a parameter to the API ie:
Content = Json.FromValue([ pageSize = "200" ]), //even though this MIGHT be the same as the default, specifying content forces the post.
finally:
Web.Contents( Url
, [ Headers = Headers
, Content = Json.FromValue([ pageSize = "200" ]) // ← This makes it a POST
