TuanPham1999
7 years agoFrequent Visitor
Pull data from API using POST method in Power BI
Hi all, I'm a fresher in Power BI Desktop. my mission is extract data from given credentials include: ClientID, Password and Url. The credentials must be Base64 encoded for use in the POST /oauth2/to...
- 7 years ago
You may refer to the following post.
https://community.powerbi.com/t5/Desktop/Connect-to-a-Web-Service-sending-parameters/td-p/225510
6 years agoNot applicable
I found it not so easy to get data via POST so I am pasting here what I did in case this helps someone else in the future.
I created the following blank query:
= let
body = "The POST method body here",
Data= Web.Contents("https://yourusrlhere",[Content=Text.ToBinary(body),Headers=[#"Content-
Type"="application/json"]]),
DataRecord = Json.Document(Data),
Source=DataRecord
Source
NateDogg
5 years agoNew Member
I wanted to post a more complete/cleaner version of the above solution that contains multiple headers and shows how to convert the body to binary data for POST operations:
url = "https://api.somevendor.com/api/",
headers = [#"Content-Type" = "application/x-www-form-urlencoded", #"Accept" = "application/json"],
postData = "Any sort of text data you want to post to the API",
response = Web.Contents(
url,
Headers = headers,
Content = Text.ToBinary(postData)
jsonResponse = Json.Document(response)
jsonResponse
