  • themistoklis's avatar
    themistoklis
    Scarthart
    Try the following formula on a measure:
    % Share =
    VAR numerator =
    SUM(INVENTARIO.....[Disponibilitad]])
    VAR denominator =
    [Rotacion Promedio Mensual]
    DIVIDE ( numerator, denominator )
    • Scarthart's avatar
      Scarthart
      themistoklis Hello, thank you very much, for answering it still does not give me what it should give me, that is, what is calculated for me in Excel, it should be the same calculation in Power BI
      Scarthart
      themistoklis Is there a way to do it without the need for SUM or SUMX , but to divide the values without grouping them
  • Hola, podrias mejor generar una columna formulada con la misma expresion y evitarias errores en la medidas
  • bolfri's avatar
    bolfri
    Icon for Solution Sage rankSolution Sage
    data that you're comparing with are different.
    Record ArticuloSourceDispon ValueRotationCalculator
    BUJA UNIVERSAL CORTAExcel on your screen13425355= 13425 / 355 = 37,8169014084507
    BUJA UNIVERSAL CORTAPower BI134250352= 134250 / 252 = 381,3920454545455
    Different data = Different results 🙂
    Both programs did thier job and gave correct results based on provided data.
    Dispon = SUM(Hoja1[Disponibilidad])
    Rotation = SUM(Hoja1[Rotación Promedio Mensual])
    Share = DIVIDE([Dispon],[Rotation])
      Scarthart
      bolfri Hi,
      How strange since all I did was export the data.
      Even so, I already discovered what is happening, is that when dividing the data accumulates and I do not want it to accumulate, I only take the value visible in the table
      bolfri
      • bolfri's avatar
        bolfri
        Is that solved your problem or do you need a SUMX calculation (measure that performes row by row and then agregate the result)? I am sorry, but I don't understand the meaning of this columns and their business meaning.
      Scarthart
      bolfri How could I split the non-summarized data as it is splitting me only the grouped correctly
