Syndicate_Admin's avatar
Icon for Administrator rankAdministrator
5 years ago
Problems with Simple Linear Regression with DAX
Hi community, I am trying to calculate with DAX a simple linear regression but I have had different problems that have made it difficult to find a solution.
For context, I have a table that contains two columns, the first is "Years of seniority" which refers to the years of seniority of a worker and secondly I have a column "Average of tickets", which refers to the average requests that a worker makes with certain years of seniority.
As an example, in the table below you can see that a worker with 1 year of seniority sends on average 7 tickets or requests, a worker with 10 years of seniority sends on average 8 tickets or requests.
If we plot this particular case and add a trend line in Excel or power BI it would look something like this
There is a simple way to calculate linear regression on the internet, but it didn't work for me.
The steps are to create 2 measures:
xsum = SUMX('Regresión_simple','Regresión_simple'[Years old])
ysum = SUMX('Regresión_simple','Regresión_simple'[N° average tickets])
Consider a categorical column (which allows you to link the two columns
and then create the following measure:
Regression =
VAR Known =
FILTER (
SELECTCOLUMNS (
ALLSELECTED ( Table[Column] ),
"Known[X]", [Measure X],
"Known[Y]", [Measure Y]
AND (
NOT ( ISBLANK ( Known[X] ) ),
NOT ( ISBLANK ( Known[Y] ) )
VAR Count_Items =
COUNTROWS ( Known )
VAR Sum_X =
SUMX ( Known, Known[X] )
VAR Sum_X2 =
SUMX ( Known, Known[X] ^ 2 )
VAR Sum_Y =
SUMX ( Known, Known[Y] )
VAR Sum_XY =
SUMX ( Known, Known[X] * Known[Y] )
VAR Average_X =
AVERAGEX ( Known, Known[X] )
VAR Average_Y =
AVERAGEX ( Known, Known[Y] )
VAR Slope =
DIVIDE (
Count_Items * Sum_XY - Sum_X * Sum_Y,
Count_Items * Sum_X2 - Sum_X ^ 2
VAR Intercept =
Average_Y - Slope * Average_X
Intercept + Slope * [Medida X]
Where bold codes should be replaced as follows
Table[Column] --> 'Regresión_simple'[Cat_ant]
[Measure X]--> xsum
[Measure Y]--> ysum
Unfortunately, graphing this measure gives me the same data as graphing the column of "Years old" and "Number of average tickets".
I would like to know if you can identify the error in using this measure or if you have another measure that allows me to do simple linear regression through DAX.
