10 years agoNot applicable
Problems with power bi using a Sybase database
Hello, I am developing a BI your DW is in a Sybase database, I have encountered many difficulties regarding the communication of power bi with sybase, the automatic load often fails and worse when fa...
the log that is entered is not readable, are just codes, the same mistake does not happen when I connect to an sql
Eric_Zhang
10 years ago
Do you mean the problem doesn't occur when using an ODBC source connecting to SQL Server? As you've said that you are using an ODBC source connecting to Sybase. Just put the two databases into the same scenario to eliminate the possibility from db side.
- Anonymous10 years agoNot applicable
thank you but it is not simple, are different environments, different customers and different projects can not migrate sybase data to sql
