Problems with power bi using a Sybase database
Are you talking about the scheduled refresh in Power BI Service? If yes, what does the refresh history say? Do you encounter the same error when the ODBC source is pointing to a SQL Server?
- Anonymous10 years agoNot applicable
the log that is entered is not readable, are just codes, the same mistake does not happen when I connect to an sql
- Eric_Zhang10 years ago
Do you mean the problem doesn't occur when using an ODBC source connecting to SQL Server? As you've said that you are using an ODBC source connecting to Sybase. Just put the two databases into the same scenario to eliminate the possibility from db side.
thank you but it is not simple, are different environments, different customers and different projects can not migrate sybase data to sql
