Problems with DAX, SQL and locale
- 9 years ago
If I do a simple test and import the data from only the table the measure needs to work with, I have no problems using Norwegian Locale. However, If I do the same, only in DQ mode, I'm back to getting the error message...
The conversion of a nvarchar data type to a datetime data type resulted in an out-of-range value... The exception was raised by the IDataReader interface.
As the source SQL-server is my own, I have also tried to change the language of the SQL instance to my own native, just to check if it had any effect, but it did not.
I found a similar post on the forums, where the exact same problems are described: http://community.powerbi.com/t5/Desktop/Locale-settings-not-working/m-p/49588/highlight/true#M19771
- v-jiascu-msft9 years ago
Hi apollnor,
According to my test, the dates will convert automatically if they are in the formats that can be converted. Sometimes the convention will return wrong date but it works unless the data is out of range. It’s hard to say what went wrong. Please check these things below.
- Please change the “Data type” of the column into Date in “Modeling” ribbon.
- Please check the dates in DB if some of them is out of range. For instance, “2017-02-30” can’t be converted.
- Change data type of that field into “Date” in the DB if possible. So we can make sure Dates are correct in the DB.
- Please post some snapshot here. (Error message, data in the DB, data in the report.)
Best Regards!
Dale
- apollnor9 years ago
Advocate II
I forgot to mention it in my original post, but I've already tested changing the data type of the date column in PowerBI using both Norwegian and English American locale. PowerBI correctly interprets the column as a date column upon querying the database.
I've also tried changing the locale of the whole model between Norwegian and English American, with different combinations on the column locale. And measures in direct query mode are unrestricted.
There should not be any problems with the way the column data types are defined in SQL. Here is an image of the table used in the example measure:
So the dates in the database are automatically recognized as dates in PowerBI or at least so it says.
Trying to create the measure works just fine:
CurrentBudget = SUMX(FILTER(DimBudget;DimBudget[TimeAltKey] <= TODAY());DimBudget[BudgetTarget])
Adding it to a visualization gives me this:
Change the locale formats of my local computer where I'm running Power BI Desktop to English (United States):
Refreshing the model in PowerBI:
So, I've done no changes on the SQL side to get this working. I've tried changing the locale of the whole PBIX-file, and the columns to both English and Norwegian without it helping. And if I change from DQ to Imported it works just fine without changing any locale settings in PowerBI.
As an additional test, I connected to the old data warehouse, where I know that things have worked in the past, and I get the same issue when creating the same measure but on a different table. Change my computers locale format to English, and it works.
I've even tried restoring the DWH database on an instance on the same computer as where I'm running PowerBI, and the exact same problem occurs, with the exact same remedies for getting it to work.
I've also tried creating a measure as so: DD = Today(), and changed the format of that measure to match the format of the time column, and using that measure instead of today() in my original measure. Works fine in American, doesn't work in Norwegian, but the DD measure iself works in both OS locale format settings.
Hi apollnor,
I reproduced this problem. The trick is the formats of date are different from each other of the DB and PBI. The workaround is changing the format of the DB or the PBI to make them same. This expression can show up the default format of the DB.
select name,alias, dateformat from syslanguages where langid= (select value from sysconfigures where comment='default language');I will submit a report internally and will post here when I get new information.
Best Regards!
Dale
