Problems when creating a VNet data gateway for Power BI
I was trying to create an VNet data gateway in Power Platform. I filled all the fields but when I clicked on "Save", the following error displayed: Ocorreu um erro: {"error":{"code":"UnknownError","pbi.error":{"code":"UnknownError"}}}. I also tried to go through the same steps with another account that has assigned role Owner of the first subscription, but in this case I can't even fill the field "Subscription", even though I can manage and have access to the same features of the other Azure account.
1 Reply
- amitchandak
InsperJr , I am hoping you are trying this - https://docs.microsoft.com/en-us/data-integration/vnet/use-data-gateways-sources-power-bi
If so log an issue at - https://community.powerbi.com/t5/Issues/idb-p/Issues
In case you trying in some code/script refer
https://docs.microsoft.com/en-us/power-bi/developer/automation/configure-credentials?tabs=sdk3
