arcegabriel
5 years agoProblems using SELECTEDVALUE in DAX
I am having an issue using selectedvalue function from a slicer. Table name is RegionTable Region field contains US, Canada, EMEA, APAC This table is used as a slicer I want to assign an a...
- 5 years ago
arcegabriel In theory something along the lines of:
OriginitatingRegionFlag = IF(MAX('Table'[OriginatingRegion]) = SELECTEDVALUE('Table1'[OriginatingRegion]),25,10) DestinationRegionFlag = IF(MAX('Table'[DestinationRegion]) = SELECTEDVALUE('Table1'[OriginatingRegion]),25,10)
arcegabriel
5 years agoThanks I understand but terribly lost on how to do that with measures.
Appreciate any suggestions or a nudge on the right direction
- ryan_mayu5 years ago
could you pls provide the sample data and expected output?
- Greg_Deckler5 years ago
OriginitatingRegionFlag = IF(MAX('Table'[OriginatingRegion]) = SELECTEDVALUE('Table1'[OriginatingRegion]),25,10) DestinationRegionFlag = IF(MAX('Table'[DestinationRegion]) = SELECTEDVALUE('Table1'[OriginatingRegion]),25,10)- arcegabriel5 years ago
Thanks, this worked well for me (had to make some adjustments to align with my model). Appreciate it
