Problems extracting data from Drill-Through (HELP!)
Over the last few weeks, I've been having trouble extracting data from Drill-Through.
This data presented an inconsistency with the data in the Database.
Where it showed a substantial amount less compared to the bank.
It was observed that some samples with date filters and type of products, proved to have fewer than 20 lines than those presented in the database.
I need help, or even a brief discussion to solve this case.
(Note 1: The graph data has a direct relationship with the number of lines, as a direct measurement is made with the source
Note 2: Drill data consists of a set of columns that are related to the fact table, but there is no direct relationship between a Drill table and the other columns)
1 Reply
- MFelix
Hi WolffOtavio ,
How are you setting up the drill-trough? Even more I do not understand note 2 if the columns aren't in a direct relationship with the drill table how do you expect to havce the drill trough correct?
