javieezy
5 years agoProblem with visual filter "TOP N"
Dear all,
Here I got a visual that I want to show only for the last 4 weeks. What can I do to get it automated filtered?
I tried to filter "TOP N" by Week Number but seems sth is wrong:
Currently, I'm updating it by "Greater than", changing the number manually every week, it's correct:
So I supposed these two filters have the same effect but obviously I was wrong, I want to know why?
Also, any other way to have the latest 4 weeks without updating manually the filter?
Thank you!
1 Reply
- amitchandak
javieezy , The first one should work
Create a measure max(Table[week number]) and use that in the filter and try.
Can you share a sample pbix after removing sensitive data.
