Dhjlm's avatar
Dhjlm
5 years ago
Problem with unique values
I have a table of shipments statistics 'Query 1', and a table with distances from our warehouse based on postnumbers 'Rev 202011'.
I'm trying to create a relationship between the postnumbers ('query1[POSTNR3]) and ('Rev 202011'[Postnr]) to see the distance for each shipment.
That will of course not work beacuse the distance column ('Rev 202011'[Avstånd (km)]) don't have unique values, simply because several posnumbers can have the same distance from our warehose.
Is there a way to work around this?
  • Hi Dhjlm ,
    In addition to what Greg_Deckler mentioned in his response, do check if there are NULL values in the columns that you are trying to create relationship on. ('query1[POSTNR3] and 'Rev 202011'[Postnr] in your case)
    I have experienced similar error in the past due to the NULL values in the key columns that are used for creating the relationships between two tables.
    Pragati
  • Dhjlm , when you getting this, while creating or when change it to many to one. ?
    looking at this screenshot difficult to tell
  • Greg_Deckler's avatar
    Greg_Deckler
    Dhjlm You should be able to create a many-to-many relationship although that is generally not ideal. You can use DISTINCT to get a table of unique values that you could use as a bridge table. But, sample data and such would be very helpful to try to see what you are trying to accomplish.
    Please see this post regarding How to Get Your Question Answered Quickly: https://community.powerbi.com/t5/Community-Blog/How-to-Get-Your-Question-Answered-Quickly/ba-p/38490
    The most important parts are:
    1. Sample data as text, use the table tool in the editing bar
    2. Expected output from sample data
    3. Explanation in words of how to get from 1. to 2.
  • Hi Dhjlm ,
    Pragati
