Problem with Shape Map / Problema com Mapa de Formas
- 6 years ago
Hi Wellingtonjr ,
When you convert it from SHP file to topojson file, please try to set it as WGS84 / EPSG 4326.
The problem could lay with the original shapefile’s coordinate or geographic reference system. Some shapefiles with less common map projections that Power BI could not support without severely distorting the image.
Here is a blog that explains it in details that you can refer:
Overcoming Potential Power BI Shape Map Rendering Issues
In addition, you can refer this similar issue, hopes to help you:
Problem using custom shape map
Yingjie LiIf this post helps then please consider Accept it as the solution to help the other members find it more quickly.
Hi Wellingtonjr ,
Yingjie Li
