Giada90's avatar
Giada90
Icon for Helper IV rankHelper IV
4 years ago
problem with relation between tables
Hi, I have relation between a lot of tables, all bidirectional, but if I put some fields of different tables on a table object it says that it's not possible to establish relation between more field...
    4 years ago
    Hi Giada90 ,
    As the error describes, the reason is that the two fields are built without a proper relationship to filter.
    I created three tables for testing:
    Relationships:
    When we drag the customer field and the product field into the visual form and set them to not aggregate, the same error is displayed:
    This is because [customer] does not have any relationship with [product], such as one-to-one or one-to-many. They can just both filtered by 'Date'[Date](one-to-many).
    If you need to relate to the many-to-many dimension,please refer:
    Many-to-many relationship guidance
    After adding the unique identifier (ID) column for each order:
    Power BI is designed to work with a Star Schema, and a good model is half the battle.
    Understand star schema and the importance for Power BI
    Gao
    Community Support Team
    If there is any post helps, then please consider Accept it as the solution to help the other members find it more quickly. If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
    How to get your questions answered quickly -- How to provide sample data
