Problem with Matrix visual and conditional formatting
Hi labulle,
This is by design, when you expand the one level, it will also expand subtotal level, then other row which not expand is also subtoal level(yellow part)
And conditional formatting is applied only to the values of a Matrix visual, and does not apply to any subtotals or grand totals.
Zoe Zhi
- labulle7 years agoFrequent Visitor
Hi Zoe Zhi,
Thanks for your answer.
You write that conditional formatting applies only to the values of a Matrix visual, must I deduce that the 1st situation I shown (all top levels collapsed) belongs to that case?
Actually, my 1st example wasn’t so fine. I found later that it’s not difficult to have a sequence of clicks that result into not painted cells, but in that case I also noticed that clicking on the "Drill up" arrow always solves the problem.
Is there any workaround that could make my cells always painted (in white or red) whatever the way the hierarchical data are displayed?
LaBulle
