Problem with Matrix total rows is not summing correctly
I'm creating a balancesheet Matrix.
I have a fact table in which i have gl_account's transactions overtime
[FTM] is the sum of trunsactions
- amitchandak
Firas_Belgouthi , You need to have measures like
CB =
SUMX(
Summarize('FACT', 'FACT'[GL_ACCOUNT_DESCRIPTION],'FACT'[ACCOUNTGROUP],'FACT'[Account_Type],'FACT'[PARTICULARS], DimDate[Year Month]),
VAR Total_T = [FTM]
VAR Average_OB = DIVIDE(SUM('FACT'[OB]), COUNT('FACT'[OB]))
Total_T +
CALCULATE(
Average_OB,
ALLEXCEPT('FACT', 'FACT'[GL_ACCOUNT_DESCRIPTION], 'FACT'[ACCOUNTGROUP], 'FACT'[Account_Type], 'FACT'[PARTICULARS])
) - AnonymousNot applicable
In matrix and table visuals, the total is calculated on the underlying data, not simply sum up the visible results in the visual. If you want to sum up the row results into Total row, you can follow a pattern introduced in the following links:
Solved: Need to summarize column with parameters - Microsoft Fabric Community
Obtaining accurate totals in DAX - SQLBI
Jing
If this post helps, please Accept it as Solution to help other members find it. Appreciate your Kudos!
