Sebastian
Advocate III
10 years agoProblem with map and postal code
Hey, I try to use the map visualization but it seems that it doesn't work well. Some postal codes where shown in the wrong country. So I try to use Land and Postal Code like Location = Conca...
joecool1863
9 years agoNew Member
I have a problem with a US postal code showing on the European side of the Map. I am only trying to get shipments out of our facilities by zip code but have state and country as part of the definition. Still, I have the following data:
| Month | Facility | Weight | CustName | CITY | State | Zip |
| February | COLUMBUS | 19540 | A***** | DORAL | FL | 33192 |
And it seems to think this is in Scandinavia somewhere. I will try adding street address and see if it makes any difference.
- chrislbs9 years agoFrequent Visitor
The problem may be that the zip code 33192 is not really in Doral but in Miami.
The lookup that Power BI is using would like it better if this said Miami. Sometimes, you may need to edit the zip code (after reading it in) to fit the visualization.
