Problem with GROUP BY for Duplicates
- 9 years ago
Hi imani_tech,
Made a small CSV file with the same fields as you have:
UserDelegatePermissions
A AA AAA A AA BBB A AA BBB B BB AAA C CC AAA C CC BBB C CC CCC C CC CCC As you can see I have repeated items, then made the grouping in Query editor and the result gives the duplicate in the count rows:
Are you already getting the information from the CSV or from the SQL that you had in your previous post?
MFelix
It should work but it isn't.
Hi imani_tech,
| A | AA | AAA |
| A | AA | BBB |
| A | AA | BBB |
| B | BB | AAA |
| C | CC | AAA |
| C | CC | BBB |
| C | CC | CCC |
| C | CC | CCC |
MFelix
- imani_tech9 years agoFrequent Visitor
I created a new query and followed your steps again. It worked! Thank you such much.
