BudSpencer's avatar
BudSpencer
9 years ago
Problem with filter in dax
hey guys,
i trying to get the total rows (V_InformeAltas[Altas Actual Col]) for previus month but now with the change of year this dax stop to work. I think i need use year and month to get the value for the previus month in this case December 2016.
Altas Ant = CALCULATE(SUM(V_InformeAltas[Altas Actual Col]);FILTER(V_Fechas;MONTH(V_Fechas[Fecha])=MONTH(TODAY())-1); V_InformeAltas[Altas Actual Col])
Can someone enlighten me?
Thx in advance
  • PavelR's avatar
    PavelR
    Icon for Solution Specialist rankSolution Specialist
    BudSpencer just use
    Altas Ant Last month = CALCULATE(SUM(V_InformeAltas[Altas Actual Col]);DATEADD('Date table'[Date column];-1;MONTH))
    don't know if the syntax is correct, I don't write it in PBI, just here in text.
    Regards.
    Pavel
    Hi BudSpencer,
    I think you should add a condition to check if these data are in the same year:
    Altas Ant = CALCULATE(SUM(V_InformeAltas[Altas Actual Col]);FILTER(All(V_Fechas);Year(V_Fechas[Fecha])=Year(TODAY())&&MONTH(V_Fechas[Fecha])=MONTH(TODAY())-1))
    Xiaoxin Sheng
