saqibahmad
8 years agoFrequent Visitor
Problem with Decimal Values in DAX, Excel(Precisely Correct ) vs Power BI (Incorrect)
Hi ,
Following is an example dataset from EXCEL and Power BI. Look at Duration column.... values doesnt match between both. I have tried changing formating Decimals, text, general in PowerBi to find exact match but no avail. Any thoughts?
Formula:
Duration = (D-C)*60*24)
| Excel | |||
| C | D | ||
| Start Date | End Date | Span | Duration |
| 24/03/2018 4:43:00 AM | 24/03/2018 4:51:00 AM | 0 | 8.000000026 |
| 24/03/2018 6:18:00 AM | 24/03/2018 6:26:00 AM | 0 | 7.999999984 |
| 24/03/2018 7:13:00 AM | 24/03/2018 7:23:00 AM | 0 | 9.999999991 |
| 24/03/2018 7:23:00 AM | 24/03/2018 7:48:00 AM | 0 | 25.00000002 |
| 24/03/2018 7:48:00 AM | 24/03/2018 8:42:00 AM | 0 | 53.99999997 |
| 24/03/2018 10:30:00 AM | 24/03/2018 3:32:00 PM | 0 | 302 |
| PowerBI | |||
| START_DATE | END_DATE | Duration | |
| 24/03/2018 4:43:00 AM | 24/03/2018 4:51:00 AM | 7.999999995 | |
| 24/03/2018 6:18:00 AM | 24/03/2018 6:26:00 AM | 8.000000005 | |
| 24/03/2018 7:13:00 AM | 24/03/2018 7:23:00 AM | 10.0000000011642 | |
| 24/03/2018 7:23:00 AM | 24/03/2018 7:48:00 AM | 24.9999999976717 | |
| 24/03/2018 7:48:00 AM | 24/03/2018 8:42:00 AM | 54.00000001 | |
| 24/03/2018 10:30:00 AM | 24/03/2018 3:32:00 PM | 301.999999999534 |
- Phil_Seamark
Hi saqibahmad
Have you looked at the DATEDIFF function?
Column = DATEDIFF( 'Table1'[Start Date], 'Table1'[End Date], MINUTE )You can choose from a number of different multiples
- saqibahmadFrequent Visitor
Thanks, I had tried your solution but original problem still persists i.e duration values are still incorrecet when compared to Excel outcome.
- Phil_Seamark
Are there millisecond values that aren't being displayed due to formatting?
