Anonymous's avatar
1 year ago
problem with dax code in a measure
Hello champs,
I have following measure but it doesn't show me values(empty cells), it doesnt say error either. When I remove  (SelectedYear - TopEventYear) > 5 at the bottom , all works correctly , it shows the total, thats fine but I don't need total what I need to achieve extra condition "greater than 5 years from total" . Any idea how to achieve it? In Months would be great as well. which is 60. I tried many ways and now I'm lack of ideas.
Measure:
pokus6 =
VAR SelectedYear = SELECTEDVALUE('Calendar'[Date].[Year])
    COUNTROWS(
        FILTER(
            CecCaseDetail,
            VAR TopFromStateID =
                CALCULATE(
                    SELECTEDVALUE(CecCaseEvent[FromStateOfProceedingID]),
                    TOPN(
                        1,
                        FILTER(
                            ALL(CecCaseEvent),
                            CecCaseEvent[CecCaseID] = CecCaseDetail[CecCaseId] &&
                            CecCaseEvent[ToStateOfProceedingID] <> CecCaseEvent[FromStateOfProceedingID] &&
                            YEAR(CecCaseEvent[EventDate]) = SelectedYear
                        CecCaseEvent[EventOrder],
                        DESC
            VAR TopEventDate =
                CALCULATE(
                    MAX(CecCaseEvent[EventDate]),
                    CecCaseEvent[FromStateOfProceedingID] = 4
            VAR TopEventYear = YEAR(TopEventDate)
                TopFromStateID IN {4} &&
                NOT(ISBLANK(TopEventYear)) &&
                (SelectedYear - TopEventYear) > 5 &&
                CALCULATE(
                    COUNT(CecCaseDetail[CecCaseId]),
                    CecCaseEvent[EventID] = 64,
                    YEAR(CecCaseEvent[EventDate]) = SelectedYear,
                    CecCaseEvent[CecCaseId] = CecCaseEvent[CecCaseId]
                ) && IF(ISBLANK(TopFromStateID), 0, TopFromStateID) &&
                COUNTROWS(
                    FILTER(
                        'CecLeadingCase',
                        'CecLeadingCase'[CecCaseId] = CecCaseDetail[CecCaseId]
HERE is picture I tried to explain how it works , we need to achieve "the green arrow " greater more than 5 years from the red rectangle. Forgot to write in the picture the Event Date column is CecCaseEvent[EventDate].
  • Hi Anonymous  - Add a debug measure to check TopEventYear and SelectedYear separately to confirm they are correctly calculated.
    DebugMeasure =
    VAR TopEventDate =
    CALCULATE(
    "Selected Year: " & SELECTEDVALUE('Calendar'[Date].[Year]) &
    " | Top Event Year: " & IF(ISBLANK(TopEventYear), "Blank", FORMAT(TopEventYear, "0")) &
    " | Difference: " & IF(ISBLANK(TopEventYear), "N/A", FORMAT(SelectedYear - TopEventYear, "0"))
    Modify your measure to handle cases where TopEventYear is blank.
    pokus6 =
    VAR TopEventDate =
    CALCULATE(
    VAR YearDifference = IF(ISBLANK(TopEventYear), 0, SelectedYear - TopEventYear)
    COUNTROWS(
    FILTER(
    CecCaseDetail,
    CALCULATE(
    TOPN(
    1,
    FILTER(
    ALL(CecCaseEvent),
    DESC
    YearDifference > 5 &&
    CALCULATE(
    COUNTROWS(
    FILTER(
    'CecLeadingCase',
    Instead of checking if the difference is greater than 5 years, check if it's greater than 60 months.
    Replace (SelectedYear - TopEventYear) > 5 with MonthDifference > 60. check this.
      sorry Iam lost now how to implement debug measure. Can you tell me what to do with the debug measure. I tried to fit in but it cause empty cell again
