FrankWe
Helper II
1 year agoProblem with data for Scatter chart
Hello all, I trying to create a scatter chart in Power BI now and have big problems to get the necessary data for the chart that I would like to create. I tried a lot of different ways that I fou...
- 1 year ago
Hi FrankWe ,
Thank you for your Patience..!!
I have created new table under "Table View" tab , please have a look at the attached pbix file.
If this post helps, then please consider Accepting as solution to help the other members find it more quickly, don't forget to give a "Kudos" – I’d truly appreciate it!
v-venuppu
1 year agoHi FrankWe ,
I wanted to check whether if you had a chance to review the information provided and solve the issue.
If so, please mark the helpful reply and accept it as the solution. This will be helpful for other community members who have similar problems to solve it faster.
