Problem with data for Scatter chart
- 1 year ago
Hi FrankWe ,
Thank you for your Patience..!!
I have created new table under "Table View" tab , please have a look at the attached pbix file.
If this post helps, then please consider Accepting as solution to help the other members find it more quickly, don't forget to give a "Kudos" – I’d truly appreciate it!
Hi FrankWe ,
Thank you burakkaragoz for the prompt response.
Ranking and tiering are done in memory using measures, not requiring a date field.
You don’t need Power Query or calculated columns – this is fully DAX-driven and responsive to slicers.
I have done some changes in the attached pbix file to replicate the scenario by creating two measures (FWE GM % Rank,Cumulative GM % and a column named Assigned Tier) as per my understanding, I hope it helps.
- FrankWe1 year ago
Helper II
Hi v-venuppu,
i just downloaded your pibx file and tried it. The problem I have still exists. Please try and remove as a test the filter text in the text slicer "Item" and see what happens. In my case I get the error that there are not enough resources available. That is the problem I have
