FrankWe
Helper II
1 year agoProblem with data for Scatter chart
Hello all, I trying to create a scatter chart in Power BI now and have big problems to get the necessary data for the chart that I would like to create. I tried a lot of different ways that I fou...
- 1 year ago
Hi FrankWe ,
Thank you for your Patience..!!
I have created new table under "Table View" tab , please have a look at the attached pbix file.
If this post helps, then please consider Accepting as solution to help the other members find it more quickly, don't forget to give a "Kudos" – I’d truly appreciate it!
FrankWe
Helper II
1 year agoI will have a look later on that. But there is no date field to sort the data. The data needs to be sorted on "FWE GM % of Selected" only using the filtered data/rows in the visual that has been filtered by the different slicers. So to be able to sort the list the values in "FWE GM % of Selected" need to be calculated first.
