FrankWe's avatar
FrankWe
1 year ago
Problem with data for Scatter chart
Hello all,   I trying to create a scatter chart in Power BI now and have big problems to get the necessary data for the chart that I would like to create. I tried a lot of different ways that I fou...
  • v-venuppu's avatar
    1 year ago
    Hi FrankWe ,
    Thank you for your Patience..!!
    I have created new table under "Table View" tab , please have a look at the attached pbix file.
    If this post helps, then please consider Accepting as solution to help the other members find it more quickly, don't forget to give a "Kudos" – I’d truly appreciate it!
