serax
4 years agoFrequent Visitor
Problem with comparing two CALCULATEDTABLES & with MAX WEEK
Dear Community, Firstly, I would like to show some sample data table and it's format. These are testing data on which I would like to explain my problem: Task description: One slicer has to b...
serax
Hello amitchandak
Your proposed solution by using RANK solved my MAX_WEEK issue - thanks! But still I have no clue how to compare two calculated tables.
Best regards!
3 years agoNot applicable
HI serax,
Perhaps you can try to use ADDCOLUMNS and LOOKUPVALUE functions to add new table columns to the current table based on id.
ADDCOLUMNS function (DAX) - DAX | Microsoft Learn
LOOKUPVALUE function (DAX) - DAX | Microsoft Learn
Regard,
Xiaoxin Sehng
