Problem with calculated column formula when recording
Good morning
I wanted to check if someone when recording a file the program modifies the formula and shows them an error.
I have the following formula in a calculated column that works OK:
When I save the file, Power Bi automatically modifies the formula (changes the "comma" to a "period") and stops showing me the result:
Could someone tell me why this happens?
Thanks for the help!
Fred
I was doing a couple of tests and found a temporary solution since it seems to me that the ones described in the message above is a Power BI bug.
So that I do not automatically change the program from "comma" to "period", create a new calculated column that does not have any formula.
- Syndicate_Admin
- v-easonf-msft
Hi, Syndicate_Admin
Thank you for sharing your workaround here.
By the way, when you create the new calculated column,you can try the 'switch' function to replace 'if'
e.g
Fecha para finaciero 2 = VAR a = FORMAT ( FAC_QueryPeridos[Fecha de entrega], "dddd" ) VAR b = SWITCH ( a, "Lunes", FAC_QueryPeridos[Fecha de entrega] - 3, "Mates", FAC_QueryPeridos[Fecha de entrega] - 1, .............other conditions, "Domingo",FAC_QueryPeridos[Fecha de entrega] - 2 ) RETURN bBest Regards,
Community Support Team _ Eason- Syndicate_Admin
Thanks for the suggestion! The formula is much neater!!!
The thing is, I don't think that's why I changed the character from a "," to a "."
Best regards!!!
