Landraille
2 years agoNew Member
problem with absolute difference calculation
Hello, I have a table containing the stock of several items for 2 softwares. I would like to compare the stock/item between the 2 softwares with an absolute difference. I tried the measure ...
- 2 years ago
This measure works
Difference abs sumx = SUMX(SUMMARIZE('Table','Table'[Stock],'Table'[Item],"A",[Difference abs sum]),[A])Furthermore, you may simplify your measure to
Difference abs sum = ABS([Difference])Hope this helps.
Ashish_Mathur
2 years agoThat link opens a sign-in page.
Landraille
Sorry, I forgot to change the rights. It's done
- Ashish_Mathur2 years ago
This measure works
- Landraille2 years agoNew Member
Thank you, the summarize function works in my case !
You are welcome.
