5 years agoNot applicable
Problem when publish panel with filter visual
Hello, I have figure out the following problem. I have created a panel with a filter visual, and configured it to be single select (it appear with radio buttons). When I publish the p...
Hi Anonymous
Have you tried it on other computers ? See if there will be the same problem. Because there is no problem in my test, it is not easy to judge the cause of the problem. Maybe you can try another computer.
