5 years agoNot applicable
Problem when publish panel with filter visual
Hello, I have figure out the following problem. I have created a panel with a filter visual, and configured it to be single select (it appear with radio buttons). When I publish the p...
Hi Anonymous
I restored your scenes , the following two are the renderings in Desktop and Service respectively . Everything is displayed normally, and there is no such thing as what you said.
The following are my steps.
(1)Add a slicer and select the type :Dropdown ,and then turn on Single select in Visual Format settings .
(2)Publish the report to Service .
I tested the scenes with version August 2021 , maybe you can update your Desktop version to version August 2021 and then publish the report to Service again .
