Problem using 'SWITCH' function
I'm trying to convert an expression from an old SSRS report to Power BI and running into the following problem. I have a table of Monthly sales figures (Jan, Feb, Mar,...) and the rows contain numerical values representing sales figures for that month.
I am trying to use the following expression but am receiving the error: "Function 'SWITCH' does not support comparing values of type True/False with values of type Number. Consider using the VALUE or FORMAT function to convert one of the values"
I found a few posts on this but I'm still uinsure of how to structure the expression for a new measure.
Monthly Sales =
(switch(Month(Now()) = 1, Sum(Jan_Value),
Month(Now()) = 2, Sum(Feb_Value),
Month(Now()) = 3, Sum(Mar_Value),
Month(Now()) = 4, Sum(Apr_Value),
Month(Now()) = 5, Sum(May_Value),
Month(Now()) = 6, Sum(Jun_Value),
Month(Now()) = 7, Sum(Jul_Value),
Month(Now()) = 8, Sum(Aug_Value),
Month(Now()) = 9, Sum(Sept_Value),
Month(Now()) = 10, Sum(Oct_Value),
Month(Now()) = 11, Sum(Nov_Value),
Month(Now()) = 12, Sum(Dec_Value))/1000)
- lbendlin
There is another option
Monthly Sales = DIVIDE( switch(Month(Now(),1, Sum(Jan_Value), 2, Sum(Feb_Value), 3, Sum(Mar_Value), 4, Sum(Apr_Value), 5, Sum(May_Value), 6, Sum(Jun_Value), 7, Sum(Jul_Value), 8, Sum(Aug_Value), 9, Sum(Sept_Value), 10, Sum(Oct_Value), 11, Sum(Nov_Value), 12, Sum(Dec_Value)) ,1000)Having values per month in different column is a design red flag.
- jdubs
Helper V
I was able to get it to work by adding TRUE() before the arguments, so:
Monthly Sales =
(switch(
TRUE(),
Month(Now()) = 12, Sum(Dec_Value),BLANK()
I could also drop the /1000 since I can just format the column directly in POWER BI.
Agreed on the data structure, but this was easier than trying to get a programmer to update the source data.
