CLANG10
4 years agoProblem using sumx() with containsstring
Hi, I am using CONTAINSSTRING to look for a specific text in a column, however i can't find the table/column, so i try using SUMX in the expression to be able to locate the column. An error occu...
- 4 years ago
Hi CLANG10 ,
try this measure
CLANG10
4 years agoHi seemd like my live data source is preventing me to use data transform/power query nor split any column. I can only create DAX measures, thus i can't test out your solution. Thanks anyway!
mangaus1111
Solution Sage
4 years agoHi CLANG10 ,
try this measure
- CLANG104 years ago
Many Thanks, it works this way!!
