CLANG10
4 years agoProblem using sumx() with containsstring
Hi, I am using CONTAINSSTRING to look for a specific text in a column, however i can't find the table/column, so i try using SUMX in the expression to be able to locate the column. An error occu...
- 4 years ago
Hi CLANG10 ,
try this measure
CLANG10
4 years agoI got the data from another live source, so i can't use power query, can only use DAX. Thanks anyway!
mangaus1111
Solution Sage
4 years agoIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
