Problem using sumx() with containsstring
- 4 years ago
Hi CLANG10 ,
try this measure
Hi CLANG10 ,
is very simple in Power Query using this code
#"Changed Type" = Table.TransformColumnTypes(Facts49_Table,{{"Display ID", type text}}),
#"Split Column by Delimiter" = Table.SplitColumn(#"Changed Type", "Display ID", Splitter.SplitTextByDelimiter("_", QuoteStyle.Csv), {"Display ID.1", "Display ID.2", "Display ID.3"}),
#"Changed Type1" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"Display ID.1", type text}, {"Display ID.2", type text}, {"Display ID.3", type text}}),
#"Removed Columns" = Table.RemoveColumns(#"Changed Type1",{"Display ID.1", "Display ID.3"})
#"Removed Columns"
I got the data from another live source, so i can't use power query, can only use DAX. Thanks anyway!
- mangaus11114 years ago
Solution Sage
