CLANG10
4 years agoProblem using sumx() with containsstring
Hi, I am using CONTAINSSTRING to look for a specific text in a column, however i can't find the table/column, so i try using SUMX in the expression to be able to locate the column. An error occu...
- 4 years ago
Hi CLANG10 ,
try this measure
VijayP
4 years agoNeed to see some datapoint to explain the solution better
CLANG10
4 years agoHi,
This is a section of my table, what i want is to find specific text in column "DISPLAY_ID" (E.G. if it contain DATA_UK, to return UK or DATA_USA, to return USA in a new column)...the problem is i can't write the table or column in my expression. Thanks in advance
