Anonymous's avatar
7 years ago
Problem using measure as argumentes in FILTER function
I am new here,
I would like help solving a problem! I'm trying to filter a table passing to a measure's FILTER function, but it does not return values, when I substitute the same measure for "text" values ​​return correctly.
Summarized Table = FILTER (OriginalTable; OriginalTable [field1] = "TEST")    -   OK
Summarized Table = FILTER (OriginalTable; OriginalTable [field1] = [measurement returning "TEST"])      -     NOK
  • AlB's avatar
    AlB
    Hi Anonymous
    Are you sure it's not context transition playing tricks? Do bear in mind that every time you invoke a measure, the DAX engine wraps the call in a CALCULATE. That in your case would trigger context transition since you have a row context in FILTER( )
      Thanks for your help!
      I'm new to the DAX language, could you kindly send me an example of using the FILTER function with measure as an argument?
      I am wanting to filter the row of a table to bring an argument to the media and filter another table with this measure.
      • AlB's avatar
        AlB
        can you show the code of your measure?
