WHDung
8 years agoNew Member
Problem using map
Hi, I just try using Power BI some days ago. Here is the problem: I could not use map. It just shows nothing. I tested the same file with my colleague's desktop. It works instead. I g...
- 8 years ago
Hi V-yuta-msft,
Thanks for your support,
Actually, the problem came from my laptop, so Power BI could not connect to Bing server and get map data. Thats why the map was blank,
Now it works nomally,
WHDung
Hi V-yuta-msft,
v-yuta-msft
8 years ago
