WHDung
8 years agoNew Member
Problem using map
Hi, I just try using Power BI some days ago. Here is the problem: I could not use map. It just shows nothing. I tested the same file with my colleague's desktop. It works instead. I g...
- 8 years ago
Hi V-yuta-msft,
Thanks for your support,
Actually, the problem came from my laptop, so Power BI could not connect to Bing server and get map data. Thats why the map was blank,
Now it works nomally,
v-yuta-msft
8 years agoCommunity Support
Hi WHDung,
Create a Table by clicking "Enter Data", then in one column you should enter country name or post code. Then drag Country column to Location field as below:
For more details about Map Visual in power bi, please refer to: https://docs.microsoft.com/en-us/power-bi/power-bi-map-tips-and-tricks.
Jimmy Tao
WHDung
Hi V-yuta-msft,
- v-yuta-msft8 years agoCommunity Support
