Problem using map
I just try using Power BI some days ago.
Here is the problem: I could not use map. It just shows nothing.
I tested the same file with my colleague's desktop. It works instead.
I got window 10 on my laptop.
Could anyone help me on that?
Hi V-yuta-msft,
Thanks for your support,
Actually, the problem came from my laptop, so Power BI could not connect to Bing server and get map data. Thats why the map was blank,
Now it works nomally,
- v-yuta-msft
Hi WHDung,
Can you share some screeshots on your own laptop when you encounter with this issue? In addtion, could you please share your PBIX file with some dummy data for further analysis?
Jimmy Tao
- v-yuta-msft
Hi WHDung,
Create a Table by clicking "Enter Data", then in one column you should enter country name or post code. Then drag Country column to Location field as below:
For more details about Map Visual in power bi, please refer to: https://docs.microsoft.com/en-us/power-bi/power-bi-map-tips-and-tricks.
Jimmy Tao
- WHDungNew Member
Hi V-yuta-msft,
- v-yuta-msft
