hild
9 years agoRegular Visitor
Problem using live connection to multidim cube
I have created a report using a live connection to a multidim cube in SSAS. It worked fine before the weekend. Sunday there was a patching of the server, and now I get an error message (shown below i...
hild
Hello!
Thank you for your reply :)
I have tried what you suggested, but still no result. Let's see what support can find out.
-Hild
Ojke
Advocate I
8 years agoHi,
I have the same issue. Were they able to help you?
Thanks for your feedback.
- hild8 years agoRegular Visitor
No, I had to create a new one.
But did you recently change the name of the cube/model? That might also cause it also. If you change it back, then it should work again :) Hope it works out! Let me know!
