hild
9 years agoRegular Visitor
Problem using live connection to multidim cube
I have created a report using a live connection to a multidim cube in SSAS. It worked fine before the weekend. Sunday there was a patching of the server, and now I get an error message (shown below i...
v-sihou-msft
9 years ago
Based on the error, it seems the issue is on the relational data source used by SSAS cube. Please test in SSMS to see if you can connect the relational data source properly. And then reprocess the cube and connect in Power BI Desktop.
If it still doesn't work, I suggest you create a support ticket.
- hild9 years agoRegular Visitor
Hello!
Thank you for your reply :)
I have tried what you suggested, but still no result. Let's see what support can find out.
-Hild
- Ojke8 years ago
Advocate I
I have the same issue. Were they able to help you?
Thanks for your feedback.
- hild8 years agoRegular Visitor
No, I had to create a new one.
But did you recently change the name of the cube/model? That might also cause it also. If you change it back, then it should work again :) Hope it works out! Let me know!
