Problem using custom shape map
- 10 years ago
I believe that when I converted your file, I lined it up with WGS 84 / EPSG 4326 -- geographic.
- 10 years ago
deldersveld Thank you so much, that works great!! Here's are screen captures of the process.
Step #1: select the shapefile using ArcGIS Project tool & set parameters
Step #2: Parameters selected
Step #3: Use mapshaper.org to convert shapefile to json format
Step #4: Save as TopoJSON
Step #5: Use TopoJSON file in Power BI:smileyvery-happy:
- deldersveld10 years ago
Resident Rockstar
ChristianDiscer: Great. I don't have an ArcGIS license, and I used QGIS. If/when I blog this, can I use your screenshots for ArcGIS users alongside my own?
- mjfulke9 years ago
I was able to take Shape Files straight to http://MapShaper.org, import them, and in the Console window, run -proj wgs84 and convert the map to something Power BI would accept.
- sweidlich9 years ago
Advocate II
This response needs to be ranked higher. Our security settings at work prevent us from installing qgis, and arcgis is too expensive. But running "-proj wgs84" in the console dialog worked like a freaking charm.
- ChristianDiscer10 years ago
Advocate I
Yes, by all means use the images in anyway possible. Thanks again for your help!!
Resident Rockstar
Did a quick writeup on it here: https://dataveld.wordpress.com/2016/09/01/overcoming-potential-power-bi-shape-map-rendering-issues/
- Anonymous8 years agoNot applicable
Hi there. Will you please be able to help me with the similar problems? Thank you in advance. My email [email protected]
- nallaa6 years agoFrequent Visitor
Hello deldersveld ,
I am trying to display City of Detroit along with Counties in Michigan map. I have downloaded and imported the City of Detroit shape file and Michigan Counties shape file to Mapshaper. I have merged 2 layers using "merge-layers" command in Mapshaper console. I was able to see the City of Detroit boundary under Wayne County of Michigan map in the output of merged file.
I have exported the output in TopoJSON format as a local file. I have converted the output coordinate system to WGS 1984 as suggested in this thread. But, when I loaded this custom map to Shape Map visual in Power BI, I am not able to find the City of Detroit's boundary in Power BI. It is displaying the whole Wayne County with out Detroit polygon.
I have checked Map keys. It is fine. When I filtered City of Detroit in my fields, the Shape Map is approximately zooming in to Detroit's geographic location in default grey color.
I need to display boundary for City of Detroit to appear so that one can select Detroit or rest of Wayne County in Power BI Shape map.
Am I missing some steps to be done in Mapshaper? Can you please help me with this?
I am sharing the source file download links below,
http://gis-michigan.opendata.arcgis.com/datasets/cities-v17a/data?where=NAME%20%3D%20%27Detroit%27
http://gis-michigan.opendata.arcgis.com/datasets/counties-v17a/data
Power BI Desktop Version: 2.84.861.0 64-bit (August 2020)
Windows 10 Enterprise
Thank you,
Abhinav
The issue has been resolved. I have uploaded 2 source files to Mapshaper. One is of Detroit City map and the Other is of Michigan County Map. I have used "erase" command in Mapshaper to erase interecting boundary between Wayne County and Detroit city. Later, I have merged 2 layers using "merge-layers" command. Finally I have used Simplify in mapshaper to repair any interscetions resulted due to above 2 operations.
Thank you,
Abhinav
