ChristianDiscer's avatar
ChristianDiscer
Icon for Advocate I rankAdvocate I
10 years ago
Problem using custom shape map
Converted shapefile (projection "transverse_mercator") to a Topo JSON file using the website http://mapshaper.org/ but the resulting JSON file has display problems.  Here's a screenshot: (1) The left...
  • deldersveld's avatar
    deldersveld
    10 years ago
    I believe that when I converted your file, I lined it up with WGS 84 / EPSG 4326 -- geographic.
  • ChristianDiscer's avatar
    ChristianDiscer
    10 years ago
    deldersveld Thank you so much, that works great!!  Here's are screen captures of the process.
    Step #1: select the shapefile using ArcGIS Project tool & set parameters
     Step #2: Parameters selected
     Step #3: Use mapshaper.org to convert shapefile to json format
     Step #4: Save as TopoJSON
     Step #5: Use TopoJSON file in Power BI:smileyvery-happy:
