Problem using custom shape map
- 10 years ago
I believe that when I converted your file, I lined it up with WGS 84 / EPSG 4326 -- geographic.
- 10 years ago
deldersveld Thank you so much, that works great!! Here's are screen captures of the process.
Step #1: select the shapefile using ArcGIS Project tool & set parameters
Step #2: Parameters selected
Step #3: Use mapshaper.org to convert shapefile to json format
Step #4: Save as TopoJSON
Step #5: Use TopoJSON file in Power BI:smileyvery-happy:
Hi ChristianDiscer,
I just tested to import an map.shp file into http://mapshaper.org/ and then export the map into TopoJSON file format. Loading it into Power BI works without any additional configuration from my side, with Power BI the same version as you posted.
So I suspect the issue here should be mostly related with the shapefile you used here. If convenient, would it be available for you to share the .shp file here for us to take a further test?
In addition, take a try to modify the Format section (the paintbrush icon) General part and see if it would help in such situation.
Adding some reference: Shape Maps in Power BI Desktop (Preview).
Charlie Liao
Thanks v-caliao-msft
Did not see a way to attach a file so use this Dropbox link to grab the file. The shapefile files are in the ZIP along with an Excel spreadsheet to "link" the map area names to: PolTwpPoly.ZIP via dropbox
Also, tried various format settings but no luck.
- deldersveld10 years ago
Resident Rockstar
ChristianDiscer: This ended up being an issue with the original transverse mercator projection. I opened the file in QGIS, converted it to mercator, and exported it back out as a shapefile. From there, it was the same process using mapshaper to convert to topojson.
This file should work: https://www.dropbox.com/s/mx4lig1vmvk4ihw/PolyTestShape.json
- ChristianDiscer10 years ago
Advocate I
deldersveld Your file conversion works very well - thank you.
However, I don't know how to properly re-project and/or transform a shapefile from my system for mapshaper.org. ArcGIS contains conversion tools, but I'm not familiar enough to know what settings to use.
Should I use a "Geographic" or "Projected" Coordinate System? Then there are many choices below these two options.
I used mapshaper.org to convert your json to a shapefile hoping to see its geographic information, but ArcGIS shows the coordinate system as "undefined." Which means I don't know what to geographic transformation data settings to use. :smileyfrustrated:
Does anyone have an idea?
Resident Rockstar
