Problem using custom shape map
- 10 years ago
I believe that when I converted your file, I lined it up with WGS 84 / EPSG 4326 -- geographic.
- 10 years ago
deldersveld Thank you so much, that works great!! Here's are screen captures of the process.
Step #1: select the shapefile using ArcGIS Project tool & set parameters
Step #2: Parameters selected
Step #3: Use mapshaper.org to convert shapefile to json format
Step #4: Save as TopoJSON
Step #5: Use TopoJSON file in Power BI:smileyvery-happy:
Hi ChristianDiscer,
I just tested to import an map.shp file into http://mapshaper.org/ and then export the map into TopoJSON file format. Loading it into Power BI works without any additional configuration from my side, with Power BI the same version as you posted.
So I suspect the issue here should be mostly related with the shapefile you used here. If convenient, would it be available for you to share the .shp file here for us to take a further test?
In addition, take a try to modify the Format section (the paintbrush icon) General part and see if it would help in such situation.
Adding some reference: Shape Maps in Power BI Desktop (Preview).
Charlie Liao
Hi Charlie,
I am facing the same issue. Will you please be able to assist me. I can share the .shp file with you.
Thank you very much in advance.
