Problem using ArcGIS for Power BI
Hello Power BI community!
I'm having an issue regarding the usage of ArcGIS for power BI: not specifically in power BI Desktop, but when I publish the report through a link so other people can see it.
Let me explain it better:
01) Inside the tool, I can make relations through the connection layer, as following;
02) The connection work and everything is done as expected. Afterward, I make another connection with another layer, as following:
03) Everything is working perfectly, and after all this process, I save the file and publish it online; (imagem below)
04) BUT: here what's weird. For some reason, in the published version of the dashboard, the 2 connection layers won't appear, he will ONLY accept 1 connection layer. (as shown here)
Is there any sollution for this?
Because in the .pbix file, it's working perfectly, with both connection layers with it's relations.
Thanks in advance!
- Greg_Deckler
LucasInfraSA Pretty odd, perhaps check with ArcGIS support?
- LucasInfraSARegular Visitor
I already contacted them, i'll have a meeting with them today!
- AnonymousNot applicable
Hi LucasInfraSA,
Thanks for reaching out to the Microsoft fabric community forum.
Just following up to your previous message, I'd like to confirm if you've successfully contacted with ArcGIS support team and were you able to resolve your issue.
I would also take a moment to thank sevenhills and Greg_Deckler, for actively participating in the community forum and for the solutions you’ve been sharing in the community forum. Your contributions make a real difference.
If I misunderstand your needs or you still have problems on it, please feel free to let us know.
Hammad.
- sevenhills
I ran into a different issue, but here's something I tried that might help:
Save a copy of your
.pbixfile with a different name on your desktop -
Publish the renamed version
Check if the issue resolves for you with ArcGIS
My hunch: ArcGIS may be caching certain settings or JS files tied to the original filename within the workspace. I didn’t dig deep since the renamed file worked for me.
If the new version works fine, feel free to delete the original and rename the new file as needed.- LucasInfraSARegular Visitor
sevenhills:
I just tried your suggestion.. but the problem continues, even with a copy of the .pbix file published.
As following:
Any other suggestions, perhaps?- sevenhills
Hmm.. it did not work. Sorry!
- v-saisrao-msft
Hi LucasInfraSA,
We haven’t heard back from you in a while regarding your issue. let us know if your issue has been resolved or not.
