Anonymous's avatar
6 years ago
Problem getting the right values for issues registered and closed
Hi there,
I have a question:
I am preparing an issue report where I have to visualize the following:
1. Date filter (let's consider the month of April 2020)
2. Calculate issues registered (Measure = SUM or Count issues based on register date)
3. Calculate issues closed (Measure = Sum or Count issues based on closing date)
4. Calculate issues before April = here I have problem: I am using the following measure:
Issues before selected month =
VAR registered =
[Issues Registered],
FILTER ( ALL ( 'Date' ), 'Date'[YearMonthNo] < MAX ( 'Date'[YearMonthNo] ) )
VAR Closed =
[Issues Closed],
Result = Issues Registered - Issues Closed
4. Calculate issues end period = Issues begin period (Before April) + Issues registered - Issues Closed
What I try to do is:
I want to know how many issues were still not closed before SELECTEDMONTH April
Issues registered in April
Issues Closed in April
Final Status = How many issues are not closed
I hope someone can help me. The scenario in Excel What I want to achieve in Power BI Desktop.
      Thank you for your reply.
      I am aware of your comment but my request is quite different.
      I need to calculate all the issues before SELECTED Month APRIL.
      Please see carefully my case.
  • v-yingjl's avatar
    v-yingjl
    Hi Anonymous ,
    If you want to get the yellow expected result just consider April, why not calculate it directly.
    Sample data:
    Issue registered = SUM('Table'[Registered])
    Issue closed = SUM('Table'[Closed])
    Issue Registered April =
    CALCULATE ( [Issue registered], MONTH ( 'Table'[Date] ) = 4 )
    Issue Closed April =
    CALCULATE ( [Issue closed], MONTH ( 'Table'[Date] ) = 4 )
    Issue Registered < April =
    CALCULATE ( [Issue registered], MONTH ( 'Table'[Date] ) < 4 )
    Issue Closed < April =
    CALCULATE ( [Issue closed], MONTH ( 'Table'[Date] ) < 4 )
    Begin period = [Issue Registered < April] -[Issue Closed < April]
    End period = [Begin period] + [Issue Registered April] - [Issue Closed April]
    Result:
    Yingjie Li
    If this post helps then please consider Accept it as the solution to help the other members find it more quickly.
      v-yingjl
      Thank you for your explanation
      I would like that " Before period" to be dynamic. means if I change the date range to MARCH then i should calculate all before March.
      • v-yingjl's avatar
        v-yingjl
        Hi Anonymous ,
        Try like this measure to calculate period month total by using the slicer:
        Issue Registered < selected month =
        VAR _month =
            SELECTEDVALUE ( 'Table'[Date].[MonthNo] )
                [Issue registered],
                FILTER ( ALL ( 'Table' ), MONTH ( 'Table'[Date] ) < _month )
        If you select March, it will calculate total registered based on Jan and Feb:
        Yingjie Li
