7 years agoNot applicable
Problem creating unique values to create a relationship
Hi I'm trying to join two tables together through a relationship but am having trouble. My data is of a Building (type text) , which has Floors and Rooms which can both be a mix of text a...
- 7 years ago
You have case sensitive in Room on Room_UniqueValues. and have null as well.
Action to be take
Change into Lower or Upper case. and remove null.
Baskar
Resident Rockstar
7 years agoYou have case sensitive in Room on Room_UniqueValues. and have null as well.
Action to be take
Thank you so much. That's solved it!
