mukundkalani21's avatar
mukundkalani21
6 years ago
Problem connecting anaconda(python) with PBI and running fbprophet. Error - python.exe not found.
Hi, I am new to PBI and python and I am trying to execute a python script on PBI. I have a time series model on python (using fbprophet) that I want to run on PBI but I keep getting the following error - DataSource.Error: ADO.NET: python.exe not found.
python.exe was not found in the specified directory. Please make sure you have a complete Python installation.
I set up a virtual environment because I kept getting an error/conflict message while trying to download fbprophet regularly on the command prompt. The virtual environment solved that issue but now it seems like PBI does not recognize python. I have tried most of the solutions online of trying to integrate PBI with anaconda but haven't really found a resolve yet. Any help with this and also generally with running fbprophet on PBI would be appreciated. Thank you!
  • v-zhenbw-msft's avatar
    v-zhenbw-msft
    Hi mukundkalani21 ,
    Please make sure that python installation selected in options page is what you expect.
    In Power BI Desktop, select File > Options and settings > Options > Python scripting. The Python script options page appears.
    Maybe this document Run Python scripts in Power BI Desktop can help you.
    Or you can uninstall and re-install the python and try again. https://www.python.org/downloads/
    If it doesn’t meet your requirement, we suggest you to open a ticket here for help: https://powerbi.microsoft.com/en-us/support/
    Best regards,
    Community Support Team _ zhenbw
    • mukundkalani21's avatar
      mukundkalani21
      Hi, thank you for your reply. I have tried the methods you suggested but it still doesn't work. Do you think it could be a PBI issue/maybe a python package issue that doesn't run on PBI?
      Python works if I don't use anaconda and just use the Python Shell itself. However I run into problems with running the specific python package.
        v-zhenbw-msft
        Hi mukundkalani21 ,
        Please update the Power BI to the latest version and try again.
        If it still has this issue, maybe it is a python package issue.
        Because we couldn't reproduce the issue here and also not found an effective solution. We suggest you to open a ticket here for help if the issue is very urgent: https://powerbi.microsoft.com/en-us/support/
        Let the engineer solve this issue from your perspective.
        Best regards,
